At one time I saw a fix to get the increased volume and premium sound without plugging in headphones but I can't find it? Anyone?
DAC fix is the only thing I know of, and requires to be plugged in.
Posted from my LG V10
I didn't know it had to be plugged it...is there any sense having it then? Doesn't the installed dac work the same way? Thanks
Lookup dac fix for lg v10 in play store.
https://forums.androidcentral.com/e...id=com.phascinate.lgv10.dacfix&token=gpqSEur5
Not sure if this is what you are talking about or not. But I have not seen anything that allows you to use the DAC without headphones. Not saying it is not there, just have not seen it..
http://forums.androidcentral.com/lg...t-hi-fi-dac-ess-technology-3.html#post4905860
