Hi, I have V20 64 GB dual sim version and the battery drains hugely even after factory reset.
Since my phone was suffering from frequent "Power supply. Tab to change USB options" notification, where it believes there's a phantom USB device connected to the phone and drains battery a lot, I did a factory reset and installed only minimal messaging apps that I know they worked fine before the battery drain issue. I am still experiencing a huge battery drain although I'm not seeing the annoying "Power supply" notification any more.
I monitored 4 hours using Wake Lock Detector (WLD) and GSam Battery Monitor with airplane mode ON.
In GSam, it shows 80% Held Awake (3% Screen and 17% App usage), 1h12m light doze, 2h39m deep doze. In App Sucker, Kernel (10.1%) and Android System (4.9%) were the top two in terms of battery consumption. See:
WLD results:
lge_charging_wake_lock is the only Kernel wakelock, is it normal?
On V20 battery menu, the battery reduced from 57% to 17% in ~4 hours and Phone idle (11%) and Android OS (6%) consumed way more than Screen (3%).
Do you see anything abnormal? Is there any other test I should do?
I really hope it's not a hardware issue. Please help. Thanks
WLD results:
