jb14
I just tested the GoneMad player. Nice user interface, by the way. It is not meant for high quality playback however. It will play via the Sabre DAC but will decimate all PCM to 48khz and converts all DSD to 48khz PCM. It will not unfold MQA files. If you have CD quality or lower, this application will work fine for you.
So miknez am I correct in thinking that with anything at CD quality (ie 16/44.1hkz) or lower the app selection doesn't matter? Or did your investigations confirm which music players reverted to the Qualcomm DAC, not the Sabre DAC? Ie should I avoid all of the listed non-LG music players to ensure that the Sabre DAC is utilised with my CD FLAC files? I only have a few 'higher resolution' files and it is clear I will only use the LG app for these.+ many thanks for the QUAD DAC link, I will need to read it a good few times to understand it completely.
