T tedsalt Member Feb 14, 2016 22 0 0 Visit site Mar 28, 2016 #1 Do Not Disturb is not turned on. On Marshmallow ... Posted via the Android Central App
acejavelin Well-known member Jun 13, 2012 1,935 27 0 Visit site Mar 28, 2016 #2 tedsalt said: Do Not Disturb is not turned on. On Marshmallow ... Posted via the Android Central App Click to expand... Try changing the ring tone used, I have seen the MM update "forget" the ringtone.
T tedsalt Member Feb 14, 2016 22 0 0 Visit site Mar 28, 2016 #3 Actually Do Not Disturb was turned on but you couldn't tell it from the menu. I found a notification that it was on and was able to turn it off. Posted via the Android Central App
