I have tried using the SMUPdater, the lastest from sholes.info to put the custom rom on my droid. The droid roots fine, but unfortunately when trying to install the rom i get the following error:
"An error has occured"
mtd: not writing bad block at 0x001e0000
I have installed no custom roms prior to this so it's a clean droid. Also if I attempt to do it again without rebooting it just gets stuck in a loop asking if i'm sure I want to install a custom rom. I'm able to back out of either with no problems and the droid continues to work in what appears to be normal. Any suggestions?
Thanks all.
Thanks all.
