Just to let you know Ron manager has version 5.0.5. I'm assuming that's the new one with apps2sd is on.
Ok so what's new with this one? Just updated not sure what's new.
Might load this up tomorrow been having to much fun with sense
Loaded 5.0.5 last night and it has been working great.
The improvements I've seen and like are the ability on the lock screen to swipe left and have the phone go to vibrate mode and not silent and hiding the zoom controls in the browser is nice too. I haven't seen any changes in speed not did I have any problems with the last stable version. I notice it freezes a lot less when I exit the browser which happened to much in the last stable version.
IMHO this is the best rom out for the Droid.
I have to wait for the phone to work outside of wifi.
I really like this ROM. Keeping it for good, Well till 5.0.6.
All the other copy and paste roms, well they are just weak (IMHO).
There are many cahnges tha might not be caught at first but they are there:
-Browser User agent (iPhone, IE, Desktop, Android)
-Vibrate or Silent on the locks screen pull tab (Depends on your Prefference Settings)
-New Orientation Menu (Off, Normal, 270 Degrees and 360 Degrees)
-Apps2SD (You need to partition your SD
-MMS Spoofing (Nokia N95, iPhone, Blackberry 8800, Sony EricssonW800i, SoftBank X01T, Custom)
-Music Widget cover art and back button
-You can remove the percentages from the battery icon (via Spare Parts)
-Fixed MMS issues
-Fixed Opening the link on certain emails
Many other fixes in framework.
Really great work (Koush, ChrisSoyars and Cyanogen)
