Koush's 2.1 Rom
  • Thread starter Thread starter Roy Aguilera
  • Start date Start date
Thanks for that info, DA. For example, I was not aware about the browser user agent. This ROM is running awesome so far.
I don't see there is any fix to the radio, is that right?
Radio? Meaning the idle and standby bug? (Cyanogen and Koush) Have come to realise that even the latest N1's (Stock) have about the same readings.
It seems that you only have an issue if you have lost signal.
Example: I have 30% stanby and 25% idle 5% display and am at 90% battery. The reading are accurate. The phone has been sitting around for the last 3 hours.
Was talking about the issue with 3g service cutting in and out.
Oh my bad:D. I have not seen that issue. What are you on 5.0.4.2?
Yes, about to go up, doing a backup now. Not sure which release it was but i've noticed places where i've always had a strong 3g service drops down to 1x and Pandora skips a lot when streaming.
You serious Jorge. Wanna know what LOL means? I'll let you know via GTalk:p
Haha I've been on the internet for a long long long time, and I never knew what QFT stood for, I knew how it was used and what was the meaning of it, but I never knew what QFT stood for lol
I know what lol means, I'm not old, remember? :P
Yea, I went there :cool:
I haven't used Pandora since I updated to the 5.0.5* version but will give it a shot now to see if I get any skips.
Been using pandora for the last hour and haven't had any issues.
According to Jay-Z 30 is the new 20 and I am not there yet ;)
And how OLD is Jay-Z? ;)
I'm quite amazed you actually know this much, a lot of older people I know are technology challanged lol
I'm having no problems with 3g or Pandora. I'm younger then Jay Z but older then DA and only a little challenged :)
I really like this ROM. Keeping it for good, Well till 5.0.6.
All the other copy and paste roms, well they are just weak (IMHO).
There are many cahnges tha might not be caught at first but they are there:
-Browser User agent (iPhone, IE, Desktop, Android)
-Vibrate or Silent on the locks screen pull tab (Depends on your Prefference Settings)
-New Orientation Menu (Off, Normal, 270 Degrees and 360 Degrees)
-Apps2SD (You need to partition your SD
-MMS Spoofing (Nokia N95, iPhone, Blackberry 8800, Sony EricssonW800i, SoftBank X01T, Custom)
-Music Widget cover art and back button
-You can remove the percentages from the battery icon (via Spare Parts)
-Fixed MMS issues
-Fixed Opening the link on certain emails
Many other fixes in framework.
Really great work (Koush, ChrisSoyars and Cyanogen)
for some reason I can't figure out where the setting is for that vibrate/silent pull tab. and does apps2sd disappear if your card isn't formatted? it's no longer showing up (greyed out) in my apps drawer
I believe if its grayed out your sdcard isn't partition correctly.
I didn't have to make any changes to get the vibrate tab.
sakhe
