will1881
Noticed you're on wifi the whole time. That probably helps with any radio signal drain
Yeah, I've been hanging around my home WiFi when not working. Thanks to Fallout 4Noticed you're on wifi the whole time. That probably helps with any radio signal drain
Moto Display doesn't cut it. But need to check that battery sot first hand on the N6P
I like Moto Display. Don't get me wrong. But the fact that it stops breathing only after 3 mins is the problem and that's unadjustable. If i could say make it at least 30 mins I wouldn't even think of the nexus.. But 3 mins only? That defeats the purpose unless you're constantly staring at the phone.
Wave your hand in front of the screen? That restarts Moto Display.I like Moto Display. Don't get me wrong. But the fact that it stops breathing only after 3 mins is the problem and that's unadjustable. If i could say make it at least 30 mins I wouldn't even think of the nexus.. But 3 mins only? That defeats the purpose unless you're constantly staring at the phone.
Someone correct me if I'm wrong, I don't get mine until tomorrow. But with the MAXX, the moto display will continue to display the notification until its been answered
Yes. The maxx is permanent. The rest are timed to 3 mins.
I read somewhere else that this was a glitch and that not everyone was experiencing this. I'm usually pretty prompt to answer my notifications so maybe I haven't let it go passed 3 min, but I read somewhere that some phones are breathing for 3 min while others are breathing for 10 min. I'll test mine out now to see what happens. My T1 definitely went longer than 3, as did my Maxx, but the breathing used to slow down after a certain point.
Yes that's all correct. It's the more recent phones that have been reduced to 3 mins. I spoke with the Moto forum moderator which he confirmed.
https://forums.motorola.com/posts/1375001d9c
