What does FDR stand for?
Curious, try turning off wifi then check stats. I have an issue when I have wifi turned off yet battery stats shows wifi on all the time using battery. Very frustrating.Dang, my WiFi is ridiculous too!! Just looked at my battery stats as I'm all of a sudden at 19%. My WiFi consumption is 18% usage and I have been at work all day not on WiFi. I mean, I always leave it on, but have never noticed that drainage until your post! What gives!?
Make sure you turn off scanning always available. It's in location in the settings, top three dots. I turned the wifi scanning on a few days ago and it was in my battery stats like you guys. I turned it off but the next day it was still in my stats, so i rebooted and did a cache partition wipe, and it is not in my stats today. Looks like there's a bug where the scanning may stay on even after turned off until a reboot is done.
Where is the setting for always scanning??? I looked in the WIFI setting and I see no such option.
Improvents.
Hi friends .
Chek This tip .restring backgraund data play store in settings. Data .
