Have you tried my advice in post 32 above? We all know that is not uncommon for Android version updates to require an FDR for some (if not many) people.Spoke too soon. Phone went back to burning up and burning through the battery. Verizon and Motorola really screwed the pooch on this update. My next phone will not be a Motorola. QC is in the toilet
Factory data reset unfortunately did not help me.Have you tried my advice in post 32 above? We all know that is not uncommon for Android version updates to require an FDR for some (if not many) people.
I've been having problems as well since the latest software update as well. I had a 30 minute drive to work - didn't touch my phone and it went from 100% to 73%.
Also, a ton of apps keep crashing on me when I open them - especially messenger. If they don't crash, they take forever to open. Even with a phone call, I'll hear the phone ringing, but the calling number/ID doesn't show up for a good 8-10 seconds...
Yes, I have cleared the cache and deleted extra apps. I even downloaded a lot of old pictures & videos to my desktop so my phone would have more space. No luck.
I've also done virus scans that turned up nothing as well.
My Moto Z Play Droid gets terrible battery life when connected to my BT headset.As far as my phone goes, I'm fairly confident at this point that the problem is Bluetooth related. If I keep the Bluetooth radio shut off, the phone doesn't get hot and battery usage appears normal. If I leave the Bluetooth radio on all the time, I will eventually experience the hot phone/massive battery drain problem. When it's doing that, if I shut the Bluetooth radio off, the phone cools down and battery usage returns to normal. The weird thing is that I can have the Bluetooth radio on for days without a problem. Also, every time I experience the problem, Android System is at the top of the battery usage list. These factors make me think that this is a software, rather than hardware issue.
If you've done a factory reset and are running a trial of visual voice mail again, that can be causing massive drain. End the trial (settings icon in upper right hand corner) and see if that helps.
Talk about a disastrous roll out.
