A
AC Question
Since Verizon pushed the Nougat update, one of the many issues I've experienced is that bluetooth is completely dead - nothing will pair with the phone. I've wiped the cache partition, done a factory reset - nothing works. Interestingly, it was working after the update and before the factory reset, but I had to do the factory reset because the battery was draining in just one hour. Any ideas?
