I see that Seidio now has the surface case and clip combo up for sale. Anyone try this yet? Does it fit the 64GB Model?
Another note: There is a guy in the case thread that thought it was too tight. I guess we need a third opinion. I'm happy and will be keeping mine.
Sent from my Droid Turbo using Tapatalk
I'm the guy from the case thread and I'm happy to say I have changed my mind and plan on keeping the Surface case. I really like the feel and I love the holster so I figured since they probalby will not make a case just for the BN that I had to make it work. I just went and trimmed a little of the felt out from the inside of the top part of the case. (about a 1/4 inch strip down each side and a little above the camera opening)
Now the fit is much better and I can get the top and bottom to meet and snap together.
Its a keeper for me!
I don't have am issue using the surface with my TYLT vu charger.How about wireless charging with this case. Had one on my s5 and the kickstand would get hot on a TYLT charger.
Can you show some pics on what you trimmed out and re-applied? I really dig Seidio cases, especially the Dilex version..
This is good information. Keep in mind that mine fit. I'm sure there are differences with each phone. This is a great case.The Green is where I trimmed and the red circle is where I added a piece to build the snap area up to make it snap better.
I really don't think you need to trim as much as I did to make it work. I'm really happy with the fit now.
In my opinion... The incipio case is much thicker than the surface. Especially the lip around the screen. It does not have the feel of the surface. Both are excellent cases I'm sure. I did not like the incipio case at all.I have used the dilex case w kickstand on my HTC DNA and currently using the incipio case for my DTBN.
How does the surface compare size wise and protection wise to the incipio?
You will love itBought my Surface case this afternoon. Very excited to get it on my Turbo!
Posted from 64GB BN Droid Turbo
