But we can't activate it?This is not what you think. This app is used for the various voice control functions for Moto Actions & Google Now functions.
It's always active, it's just part of the phone's operating system if you will. If you want an app for recording, there's a number of good ones available in the Play Store. When you search, ask a question or give a voice command the sound is recorded then transmitted according to the task you are performing. I'm not certain but I think the integral recorder is also used by Verizon's Visual Voice Mail to record the messages on the phone. Since this is a dedicated purpose utility, it's easy to understand why it's not available for other uses. FWIW, I use Easy Voice Recorder Pro as well. .But we can't activate it?
However the app I download from the Google play gives out a poor performance probably due to the lack of noise cancellation.
Thanks though.
