I dont have any hard bumps, to be honest I'm not sure I know what your talking g about. Is it a bump in the glass area next to the camera?
I posted an image with a red mark where the bump would be located earlier. Look a few posts back .
Mine has the same bump. You can really notice it with a clear case so I changed to a different case
Oh ok, I thought the bump was supposed to be on front. I usually view this forum from my phone so I couldn't see you attachment until I checked request desktop site on chrome...next time its life proof is off I'll check, maybe tomorrow. Now I'm curious. I do t sense any static to complain about though
ive thought about it but then Id probably be on it more than I should, and no I dont have a hard bump, seems perfectly smooth and curved like it should be and no sense of static. THere is a muffle when its in the lifeproof but that doesnt count
I wish I could see in person what this bump looks like, interesting. I know this was said earlier in the thread but what if you take the back off, I too have heard its very easy, and just see what it is?
Just to add to the pool.. I haven't been able to detect a bump in the location specified (or anywhere, for that matter). And my speakers have no static that I have noticed.
to me that photo does show what the creaking sound when you press on the back is. I would bet its the wireless charging pad. The ballistic nylon back isnt 100% rigid, its probably pretty flexible (but strong) so when you press it your probably hitting the charging pad. Im sure it isnt bad
jeez it was bad enough to deform the case? I want to see one of these bumps. Im curious. If I were you id have taken it apart before exchanging it, they wouldnt have known and wouldnt have matteres
