vzwuser76
I did a short test last night. Cleared my cache partition did a top off on the battery and then let it sit idle to see the battery draw. I'd usually lose around 3% an hour on 4.4, I'm losing 1.4% an hour after the updating.
Another note now, although I'm sure most of you know this. I did a wipe of the cache partition and then went to do something else, assuming that it worked like it always did, clear the cache and then boot normally. After the update however, when it's done it now brings back the recovery mode screen asking you if you want to reboot. I was busy last night so when I came over about 5 hours later, I found my screen on showing the recovery screen. My battery was at 70-75% before I did the cache wipe and it was at 17% after 5 hours. So a word of advice, don't leave your Turbo unattended after starting a cache partition wipe.
