A
AC Question
My Droid Turbo won't connect calls with my Nissan Altima bluetooth
I have a new Droid Turbo with version 5.1. I have a 2014 Nissan Altima S. I synced the phone to my bluetooth and it worked and I drove for a while, made a few calls, etc. Then, I went to work and when I got back into the car it indicated that the phone was connected, but when I made a call the display on the dash would be stuck on "dialing" and I could not connect the phone call. I tried to make the call from the phone itself and from the car and the same thing happened in either case. When I would receive a call it wouldn't even come through the bluetooth and I would have to manually change the setting on the phone to "handset" in order to speak to the person. Can anyone give me direction on how to fix this issue? By the way, I can connect any other device to my car and it works perfectly so the car is not the problem.
