I was charging it and the battery was about 3/4 full, so I took it off of the charger but then I tried to turn the screen on and it wouldn't. I also tried to hold the power button and nothing happened.
Printable View
Welcome to Android Central! How long did you hold the Power button for? Hold it for 15-20 seconds, if you haven't done so already.
If that doesn't work, see if you can boot into Recovery: https://motorola-global-portal.custh...p/30,6720,8697
