Problems!
Flawson
165
3
Okay, so I had been trying to go to leaked 2.2 in advance of the ota per those waiting on birdman. BUT! I never could get the update.zip to work...i rooted, no problem. Then I tried the manual flash method to install update.zip. Nothing. Then I tried rom manager, with the bootstrap of course. Nada. I tried it with and without moving su. Nothing worked! So I decided this morning that I give up, i'l just take the ota. But that won't install, either! So I unrooted, and before doing so made sure that su was back in it's place and that my update.zip leak was no longer in the root of the sd card. Nothing again!
So do I need to do a factory reset or something?
Sent from my DROIDX using Tapatalk
Non
