Just got the 5x today, but my xiaomi piston 2 headset is very hard to plug in, and plays sound only 1 in 10 tries or so. I tried an iPhone headset which plugs in easily, but no volume control (as expected) and it works consistently. To be honest, I'm not sure if the phone's jack is the issue or if it's a headset compatibility issue with the xiaomi.
Can you recommend a quality pair of wired headsets compatible with the the Nexus 5x and that are able to control volume and also start/stop playback?
Thank you!
Thank you!
