i bought a used 6p and i only get abt 2.5 hours SOT. my wife consistently gets 3.5-4. how can i check if the battery is physically bad. all the stats look good. no power hungry apps.
You can't really physically test it - all you can do is check how it behaves. I'd suggest charging it fully, then putting it in Safe mode while you sleep. For 8 hours or so just sitting idle it should only lose a few percent.how can i check if the battery is physically bad. all the stats look good. no power hungry apps.
