I have a Nexus 6P that I have owned since 2015. The Android software does not execute but instead shows an error showing "No Command". Can you please advise how I should fix this?
Printable View
Welcome to Android Central! The firmware might have become corrupt, or the motherboard might be failing. Are you able to boot into Recovery Mode and do a factory reset from there? https://www.hardreset.info/devices/h.../first-method/
