tvall
and this place is cluttered to hell already with too many ROMs, we don't need any more devs.
There is no such thing as "too many devs"! I think we could use more.
Well, if you're cool with it and it isn't any trouble for you, that would be cool. I'd just need to set up an SSH client on my end, right? Any recommendations?
You might need more zvh/zvj files to work with IHO. This fixed some of the problems before using Drew's kernel with cm7. Main issue was with the camera and white screen previews. The files linked are from zvh, and i haven't updated it to zvj files. http://forums.androidcentral.com/lg...ptimus-s-thekraven-2-7-2012-zvd-only-153.html
You might look at using more proprietary files and the ril files from zv9. I can't remember what zefie did during the sprint changes from zv9 to zvc and zvd. I know he updated kernels with the baseband changes. Have they released the Virgin zv9 kernel sources yet?
3G should work fine on builds from my repo, what does logcat show?
As for IHO, if you can't sync, try again later. Network issues at either end can cause errors syncing (unless you have a specific error message beyond http).
I have done the comparison; all of the proprietary files in the ZV9 update package from VM are the same with the files that are already in IHO repo. There is just a single file difference (I don't remember which right now) and it is not radio related. I suspect that the problem some users are reporting are due to the radio image itself. I don't have any problems with three ZV9-OVs with my usage pattern and personal configuration. I still use Bob's v3.7 kernel binaries that I had used with ZV4 and ZV5.
All, I have updated my Ubuntu server that I also use for Android builds from 11.10-x64 to 12.04. There were no problems with Android builds. FYI, in case you were wondering.
clodfelterac@myUBUNTUlaptop:~/android/system$ repo init -u git://github.com/inferiorhumanorgans/android.git -b gingerbread
No command 'repo' found, did you mean:
Command 'rep' from package 'rep' (universe)
Command 'repl' from package 'nmh' (universe)
Command 'repl' from package 'mailutils-mh' (universe)
repo: command not found
help please?....
i guess not... been following onlyunless' tutorials... updated java done... sdk done... eclipse done... following the directions on the first page and this is where im stuck... skipped dl of 64bit libs as im deving on 32... would appreciate any help... thanks for replying!...
32 you say?... yes, it works and im poor... lol...
This stuff is just way too confusing and frustrating. I am in way over my head, thinking I'm on the right track and then hammered with more errors. Is there no...centralized starting point to learning ROM development? Is the process really just hunting and pecking until it works? If so, then I'd happily continue, but right now I am learning nothing by sending PMs and / or posting here every time an error comes up.
Do you have a Google talk account? I'm sure someone here would gladly chat with you and help fix errors.
cole2kb@athena:~/android/thekraven$ lunch
You're building on Linux
Lunch menu... pick a combo:
1. full-eng
2. full_x86-eng
3. vbox_x86-eng
4. cm_thunderc-userdebug
5. generic_olympus-userdebug
6. generic_sunfire-userdebug
7. cm_anzu-userdebug
Which would you like? [full-eng] 4
Looking for dependencies
Dependencies file not found, bailing out.
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=4.0.4
TARGET_PRODUCT=cm_thunderc
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv6-vfp
HOST_ARCH=x86
HOST_OS=linux
HOST_BUILD_TYPE=release
BUILD_ID=IMM76D
cole2kb@athena:~/android/thekraven$ make bacon
TARGET_BUILD_APPS=
TARGET_ARCH=arm
HOST_ARCH=x86
HOST_OS=linux
BUILD_ID=IMM76D
Checking build tools versions...
system/core/toolbox/Android.mk:98: warning: overriding commands for target `out/target/product/thunderc/system/bin/lsof'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/bin/lsof'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/etc/mkshrc'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/etc/mkshrc'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/root/ueventd.rc'
system/core/rootdir/Android.mk:49: warning: ignoring old commands for target `out/target/product/thunderc/root/ueventd.rc'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/root/init.rc'
system/core/rootdir/Android.mk:42: warning: ignoring old commands for target `out/target/product/thunderc/root/init.rc'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/etc/hosts'
system/core/rootdir/Android.mk:31: warning: ignoring old commands for target `out/target/product/thunderc/system/etc/hosts'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/bin/dhcpcd'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/bin/dhcpcd'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/egl/libGLES_android.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/egl/libGLES_android.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/bin/e2fsck'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/bin/e2fsck'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/bin/rild'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/bin/rild'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libmm-omxcore.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libmm-omxcore.so'
build/core/Makefile:36: warning: overriding commands for target `out/target/product/thunderc/system/lib/libOmxCore.so'
build/core/base_rules.mk:523: warning: ignoring old commands for target `out/target/product/thunderc/system/lib/libOmxCore.so'
build/core/Makefile:66: warning: overriding commands for target `out/target/product/thunderc/root/default.prop'
build/core/Makefile:36: warning: ignoring old commands for target `out/target/product/thunderc/root/default.prop'
No private recovery resources for TARGET_DEVICE thunderc
build/core/tasks/kernel.mk:37: ***************************************************************
build/core/tasks/kernel.mk:38: * *
build/core/tasks/kernel.mk:39: * No kernel source found, and no fallback prebuilt defined. *
build/core/tasks/kernel.mk:40: * Please make sure your device is properly configured to *
build/core/tasks/kernel.mk:41: * download the kernel repository to kernel/lge/thunderc
build/core/tasks/kernel.mk:42: * and add the TARGET_KERNEL_CONFIG variable to AndroidBoard.mk*
build/core/tasks/kernel.mk:43: * *
build/core/tasks/kernel.mk:44: * As an alternative, define the TARGET_PREBUILT_KERNEL *
build/core/tasks/kernel.mk:45: * variable with the path to the prebuilt binary kernel image *
build/core/tasks/kernel.mk:46: * in your AndroidBoard.mk file *
build/core/tasks/kernel.mk:47: * *
build/core/tasks/kernel.mk:48: ***************************************************************
build/core/tasks/kernel.mk:49: *** "NO KERNEL". Stop.
cole2kb@athena:~/android/thekraven$ find -name AndroidBoard.mk
./build/target/board/emulator/AndroidBoard.mk
./build/target/board/generic/AndroidBoard.mk
./build/target/board/generic_armv5/AndroidBoard.mk
./build/target/board/vbox_x86/AndroidBoard.mk
./device/lge/thunderc/AndroidBoard.mk
./device/motorola/olympus/AndroidBoard.mk
Notice file: device/lge/thunderc/apversion/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/lgapversion.txt
Notice file: bionic/linker/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/linker.txt
Notice file: bionic/libc/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libc_nomalloc.a.txt
Notice file: system/core/logcat/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/logcat.txt
Notice file: system/core/logwrapper/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/logwrapper.txt
Notice file: frameworks/base/media/libmedia/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libmedia_helper.a.txt
Notice file: external/mksh/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/mksh.txt
Notice file: external/mtpd/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/mtpd.txt
Notice file: system/core/netcfg/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/netcfg.txt
Notice file: external/bluetooth/bluez/compat/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/pand.txt
Notice file: external/ping/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/ping.txt
Notice file: external/ppp/pppd/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/pppd.txt
Notice file: external/ipsec-tools/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/racoon.txt
Notice file: external/ipsec-tools/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/lib/libipsec.a.txt
Notice file: hardware/ril/rild/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/radiooptions.txt
make: *** No rule to make target `out/target/product/thunderc/obj/lib/libril.so', needed by `out/target/product/thunderc/obj/EXECUTABLES/rild_intermediates/LINKED/rild'. Stop.
make: *** Waiting for unfinished jobs....
Notice file: hardware/ril/rild/NOTICE -- out/target/product/thunderc/obj/NOTICE_FILES/src//system/bin/rild.txt
