diff --git a/src/common_audio/signal_processing_library/main/interface/spl_inl.h
index 8716ca9..6e20df6 100644
--- a/src/common_audio/signal_processing_library/main/interface/spl_inl.h
+++ b/src/common_audio/signal_processing_library/main/interface/spl_inl.h
@@ -19,10 +19,19 @@
#ifdef WEBRTC_ANDROID
+__asm (
+ // On Android gcc compiler, the clz instruction is not supported with a
+ // target smaller than armv7, despite it being legal for armv5+.
+" .arch armv7-a\n"
+//" clz %0, %1 \n"
+//"=r" (leading_zeroes)
+//"r" (data)
WEBRTC_INLINE WebRtc_Word32 WEBRTC_SPL_MUL(WebRtc_Word32 a, WebRtc_Word32 b)
WebRtc_Word32 tmp;
- __asm__("mul %0, %1, %2":"=r"(tmp):"r"(a), "r"(b));
+ __asm__("smmul %0, %1, %2":"=r"(tmp):"r"(a), "r"(b)); //changed mul to smmu
return tmp;
@@ -66,7 +75,7 @@ WEBRTC_INLINE WebRtc_Word16 WebRtcSpl_AddSatW16(WebRtc_Word16
WebRtc_Word32 s_sum;
- __asm__("qadd16 %0, %1, %2":"=r"(s_sum):"r"(a), "r"(b));
+ __asm__("qadd %0, %1, %2":"=r"(s_sum):"r"(a), "r"(b));
return (WebRtc_Word16) s_sum;
@@ -86,7 +95,7 @@ WEBRTC_INLINE WebRtc_Word16 WebRtcSpl_SubSatW16(WebRtc_Word16
WebRtc_Word32 s_sub;
- __asm__("qsub16 %0, %1, %2":"=r"(s_sub):"r"(var1), "r"(var2));
+ __asm__("qsub %0, %1, %2":"=r"(s_sub):"r"(var1), "r"(var2));
return (WebRtc_Word16)s_sub;
