O one80oneday Well-known member Jan 25, 2011 289 17 0 twitter.com Feb 10, 2012 #1 Can we boot this? http:// forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/155015-wip-rom-cyanogenmod-9-lg-optimus-s-yes-its-ics.html
B bdfull3r Well-known member May 11, 2011 290 24 0 Visit site Feb 10, 2012 #2 one80oneday said: Can we boot this? http:// forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/155015-wip-rom-cyanogenmod-9-lg-optimus-s-yes-its-ics.html Click to expand... no we can't. We have different configuration. Though in theory a port wouldn't be too hard to accomplish.
L LeslieAnn Android Developer Feb 8, 2011 2,895 1,720 0 Visit site Feb 10, 2012 #3 It will probably boot, but at the very least, you will have no data. If you try it, be prepared to have to re-activate when you flash back. Make sure there is no radio image included either or it will destroy your phone.
L lanier420 Member Dec 16, 2011 10 1 0 Visit site Feb 11, 2012 #4 Just flashed the optimus s ics beta rom on my optimus v .... I have no service maybe changing the prl will fix the problem
E Eollie Well-known member Feb 22, 2011 1,534 258 0 Visit site Feb 11, 2012 #6 lanier420 said: Just flashed the optimus s ics beta rom on my optimus v .... I have no service maybe changing the prl will fix the problem Click to expand... No. its not built for the Optimus V it needs to be ported to work properly.
O one80oneday Well-known member Jan 25, 2011 289 17 0 twitter.com Feb 14, 2012 #7 I don't think Optimus S had service working yet either. Looks like this thread has more info http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/155270-cm9-v-wifi-works.html
L LeoLawliet Well-known member Nov 26, 2011 713 108 0 Visit site Feb 15, 2012 #8 just flashed it, liking it so far. There's still some lag but it's surprisingly smooth Sent from my LG-VM670 running IHO MiRaGe using Tapatalk
