[ROM][WIP]OptimusWiz[06-07-2012]
arnold1997
693
117
I am absolutely LOVING this rom. I have tried SEVERAL over the past few months and nothing has satisfied my needs, but this ROM just rocks! It is also surprisingly LEAN. I now have 180mb total with 110mb free after flashing rom and installing all my apps.
One small question, and it may be a dumb question, but how do I get apps to stick to the bottom quick launcher? After I flashed the rom, I have the "messages" and "app drawer" buttons, but I can't add any more app icons as the trash bin pops up and it just deletes the icon from the screen instead of adding to the quick launch.
Otherwise, great ROM! I highly recommend this one. :)
Thanx !
and for rhe bottom goto to the app drawer then.press menu button then edit. After u press edit you can drag any app to the dock
Reactions: chadbot3k
arnold1997
693
117
And yes the the free space was one of the goals of the rom :D
Im happy you like it :thumbup:
xxlemonxx
254
29
Re: [ROM][WIP]OptimusWiz[04-22-2012]
Flashed this a few days ago, i do like it. I just wish the launcher went to screen 3 when hitting home and kept the screen # up but thats not your fault :p Love the rom though
arnold1997
693
117
You can pinch the homescreen the homescreen then press menu i think and then you can modify your homescreen :D
xxlemonxx
254
29
I dont have time tonight to re flash and what not ill try it out though. Do you plan on updating it in the next month or so though?
Reactions: arnold1997
arnold1997
693
117
Widgets I'm almost positive ill add. Lock screen its gunna be a bit hard without an external app but ill do what i can :p
Sent from my LS670 using Tapatalk 2
kcls
901
307
63
Yupp thanx for the feedback. And the lockscreen must be in the framework-res..
I haven't been following this thread, but I'm assuming you want a touchwiz style lockscreen? If so, I recommend MiLocker with a .mtz theme. There are several that have been ported to MDPI.
Sent from my LG-VM670 using Tapatalk 2 Beta-5
arnold1997
693
117
Havent thought about that!! Thanx ill have to give u credit for that ;)
Ill have an update uploaded by the end of next week!:D
chadbot3k
6
This is most excellent news, not that I can see much wrong with this rom...
I'll keep my eyes on this thread, this little rom is really making my OV a powerhouse! :D
epicb0dyc0unt
238
28
This is a very well put together ROM. It's very light on the apps on boot and has great speed and responsiveness. Bravo to this ROM and you Arnold. Brilliant work my friend!
RandyRoyalty
