Cold As Ice working on Optimus V!
andrewnelson23
795
145
Oh, I was talking about the browser youtube :p
On another note...Is there anyone that could possibly make a theme for CM9 to something similar to this? I pm'd the maker of these a couple weeks ago, but he isn't active and didn't respond. His dl links are broken, as well. If anyone could make this, that'd be freaking awesome. OR, if someone wants to walk me through on how to make something like this, feel free to pm me. Thanks :)
The theme website is http://forums.androidcentral.com/op.../162404-theme-wip-legend-zelda-theme.html#anb
OppyV
Active member
Jun 26, 2011
43
8
Only real problems I have that I know are rom-specific are the clock lag (both lockscreen and status bar), laggy hq youtube, and hanging voice search. Edit: Also (And this is kind of major)... Speakerphone problems! Can't use speakerphone at all. Other than that (which i know will be fixed soon now that most of the basic stuff is squared away), roms fantastic!
Also I tried that hosts file fix (I deleted it) for streaming music (specifically Google Play Music) it works and allows me to use 3G streaming more often but I still have fc's (not often though) that im not sure are related to the hosts file. Just a heads-up.
I wonder if he'll do an AOKP version that'd be nice :D ICS Reloaded is ok but it just doesnt compare to full on AOKP to me.
Kahroo
Android in training
Mar 13, 2011
199
7
I'm kinda confused on how to install this.
So I should download Alpha 10 flash that, then flash GApps. Should I flash HydroKernel to fix the camera? It says the camera is working...somewhat in alpha 10. Or is there another Kernal I should flash. Then I shoulld Install. CM9 Reloaded.
Sorry for the noobish questions. I have only ever installed 1 ROM before and that was BACKside. So I am not used to flashing roms and doing all this extra stuff. I am just used to downloading a rom, installing it and done.
EDIT: Also what does ZVD only mean?
bbruno8
19
8
You should flash the alpha 10G then GAPPs and finally the VM fix. The kernel comes in the ROM already.
ZVD... I'm not sure sure but it could be related to some devices with different radios? I really don't know this answer this question, sorry.
Sent from my LG-VM670
Kahroo
Android in training
Mar 13, 2011
199
7
Ah thanks. I want to hold off and wait till I know what ZVD means. Cause on the original post it says ZVD Only
andrewnelson23
795
145
ZVD is a radio type. If your baseband version in settings>about phone phone ends in zvd, then you have a zvd radio. If it ends in something else, you don't. If you don't end in zvd or zv9, you proly need to update your radio type to zv9 if you haven't already. Go here to find out how to do this. Then you're good to go :)
Kahroo
Android in training
Mar 13, 2011
199
7
Ah ok. My baseband is VM670ZV4. So yeah I would need to update it to use any ICS ROMs right?
Octahedron
321
47
Nonono, us OV users don't have to worry about our radio version. I'm on vm670zv4 and cai works like it's supposed to.
Edit: a screenshot for proof.
Sent from my VM670 using Xparent ICS Blue Tapatalk 2
Octahedron
321
47
anthonycr which one? It has to be zvd.......also Im not the one who said that you need zvd or zv9 to run cai, it is ZVD.......duhhhhh
Only OS users need to worry about baseband. The OS baseband gets updated while the OVs is always the same. Which means we can use any custom rom (except froyo) and not have to change our baseband.
Kahroo
Android in training
Mar 13, 2011
199
7
@Kahroo, right here VM cm9 a10 fix
Thanks a lot. So I'm about to install so what I do is flash alpha10G, Gapps, VMFix then reboot?
Or can I flash alpha10G, Gapps, VMFix, ICS Reloaded, THEN reboot?
Edit: I also have ClockworkMod 3..2.0.1 that I had installed from ROM Manager like a LONG time ago. And it has been working for me when I install new updates for IHO BACKside. So should I change it to something else or just keep it since it works for me?
And also do I need to fix the Key layout? Since the S Home and Menu and switched. And if so can someone give me the link since the one in the first posts link is no longer there
