Thraeryn
DEVASTATOR
Has there been a fix or workaround found for the Google Now scrolling issue? Searched the thread, didn't see one mentioned.
Not that I'm aware of. I'd like to know if there's a working version for any OV ROM. I'd really like to check it out.
Here on BobZ CM10, I just downloaded the Google Search apk from I think some link from that OTHER place, sideloaded it into my phone, so it is actually running off SD-Ext. It works dine, but since the mic doesn't work, you can't use the Voice part. But the cards work, so does search. My only gripe is it occasionally crashes and exits, which is more prevalent if you try to open about 5 mins after your phone reboots and restarts.
Do you think you could post a link? I'd love to try it with the previous build that had the working mic.
Not just you. I believe this is one of the current issues. WiFi turns off and on it every so ofter it seems, but I am unsure if it is draining more battery this way, perhaps because of deep sleep issues that still exist.It seems when my phone goes to sleep the data/WiFi turns off till I turn the screen on. Any fix for this or is it just me?
Thanks, I'll give it a try tomorrow. Can I replace the voice search apk in the gapps with this one and flash it? I was planning on doing a clean install of Bobz previous build anyway. Idk if it will be too big, but it's worth a try.
Sent from my GT-P7310 using Android Central Forums
No you can't. I tried to sideload the new voice search apk and then the new search apk and voice still doesn't work.
---------- Post Merged at 11:28 AM ---------- Previous Post was at 11:28 AM ----------
Anyone having problems with data on the v. I, know it's not the roms. I've tried five today trying to fix the problem. When data is downloading, it goes to
1x with full bars. When not downloading it goes to 3g with one bar. Then full to none with in seconds. Do, I have a hardware problem or is it virgin missing with me.
Two problems I'm encountering.
1. 3G Issues. I'm using the app power toggles and when I turn off 3g at times, the 3g is still turned on. the only way around this is rebooting the phone. It might be just the power toggles app but I don't know.
2. USB Connection. In order to connect to my computer via USB, I have to turn on Android Debugging and then turn it back off.
Went back to ICS, once data is fix on this rom I'll for sure go back.
+1 3g stills drops....
