Dev work isn't really that easy. To flash Pac-rom you need to flash the my in the right order. If you flashed the virgin fix first it won't help anything.
1. Flash the rom
2. Flash gapps
3. Flash virgin fix
4. Flash cronmod's int2ext patch
Without int2ext it won't have enough room for apps. do you have an ext partition?
Tapatalk'n it PAC-Rom style! Android 4.2.2 on my VM670 running LS670ZVJ firmware
Okay I didn't say dev work was easy. I'm a nerd. I learn quickly and efficiently. It might be easy for me I mean most super high tech stuff is for me. I outsmarted nearly all tech support operators that I've ever communicated with.
Anyway I don't see how nobody else installs this. Let me explain very clearly. Installing the rom first will not work because the build.prop file clearly states that the rom is for ls670 not vm670. It aborts the installation.
And yes I have sd-ext. I use mounts2sd first (after downloading busybox for a "just in case") to configure busybox settings and create an init.d script, reboot, load up Link2SD and select my ext type, reboot, then link everything that I can using Link2SD. I know how to properly utilize Titanium Backup Pro along side Link2SD. Just have to restore in segments.
So yeah. How can I install the rom first if build.prop stops me? Good luck.
