Well crap, the rectangle piece under the screen that makes the finger print reader is very very visible in direct sun. I was typing outside in the sun today and was clearly able to see it through my Gboard keyboard (white color).
I then started placing other light color objects and it is so easily noticable. Even on the AOD I can see it too if you look closely in direct sun light.
Please see pictures below and someone confirm if they see the same issue on their devices. You can only see this in direct sun light. Any shade and you won't see it.
