Has anyone else seen or read this? Could this affect the Note 10 & 10+ series?
Samsmome
270
I have the factory installed screen protector on. I also have WSD screen protector which I haven't used. I was waiting until the original gets messed up.
I saw it in the news today. Some are speculating the thumbprint was on the glass and with the screen protector over the glass the residual fingerprint may be getting pressed onto the sensor. Samsung appear to be looking into this so we shall need to wait to see what transpires. It is certainly a potential safety breach so for now I have reverted to a PIN
The original article is from The Sun. That publication is pretty much the UK's version of the National Enquirer. It's a tabloid and is not known for reliable, or even factual, reporting.
you would think a flaw like that would make all the major tech sites news. since it did not, imo,it is nothing to worry about.
I doubt it would affect the Note series, seeing how most complaints are how their FPS with a screen protector doesnt work, lmao.
I'm fine with my WSD glass and Note10+. It works. Maybe not instantly like most say it does or should, and maybe not even 100% every time, but I really don't feel it's that big if a concern, as long as its keeping others out as it's supposed to.
Damn I miss my Note 9 perfectly working sensor... Progress for the sake of progress
I got an update today with improvements to the fingerprint scanner, separate one from the October update the other day
Hi
Just received this update now. So it is a issue which has been posted by Sammobile and various other tech sites.
Looks like Samsung are sorting it out hopefully
Looks like you 5G guys are getting the updates faster than the 4G handset, nothing here yet.
Hi
All that goodness in 17MB. Now, if only it would multiply for every 17MB 😄
liquidsnake757
