text has no sound
Kent Douglas
3
my new note 10+ makes no sound for text, will vibrate, but no sound.in settings , under new messages, then sound I get this text no sound.jpg. folders are empty. tried uninstalling and reinstalling. rebooting. OS is up to date. I have the same problem with an alarm app. will not let me get to my sounds or ringtones.
anon(10614692)
2,452
Open Samsung Messages then click the 3 dots on the right then click settings then Notifications then click on General Notifications and see if there's a Sound listed if not add one then go back and click on new messages which is right below General Notifications and see what it has listed
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Either use your file manager or connect the phone to a PC (either way does the same thing.) If there's no folder named Notifications (case counts), create one. Choose the sound you want for an incoming text and put it into that folder. Go back to messages and select that notification sound.
(And make sure that your volume levels are all turned up.)
