jsmat
Re: Battery Drain after 4.3 update
Yup. Already looked it up. We're having issues with 4.3. There is no such option (select runtime) in 4.3
Sorry, here it is. Go to Select Settings, Developer options, select Runtime. change the setting to Use Dalvic. Reboot the phone. Once phone comes back it will update you apps. Next, go to Settings, Backup and Restore and select Factory Data Restore. Phone will put to factory restore. Please save all your data, apps information, SMS's etc because phone will be "completely" wiped out. I hope this helps. This worked on my Google Play Edition HTC One running 4.4.2
