jimd1050
Champion
Sweet... let us know how they fit/install/work/etc. - please, once you try them?Just in.
I doubt most Note users need/use the replacement tips so Samsung probably realized they could save money by not including something 95+% of users didn't need. As a regular note user I have countless little bags of S-Pen tips but have never needed to replace them. Some people may draw/write heavier-handed/stronger than others which may be why some users that use the pen regularly have never had a need to replace the tip while some others go through multiple tips in their Note's lifetime.I ordered from Amazon. The S-Pen does use replacements but for some reason Samsung didn't include any this time around.
I doubt most Note users need/use the replacement tips so Samsung probably realized they could save money by not including something 95+% of users didn't need. As a regular note user I have countless little bags of S-Pen tips but have never needed to replace them. Some people may draw/write heavier-handed/stronger than others which may be why some users that use the pen regularly have never had a need to replace the tip while some others go through multiple tips in their Note's lifetime. **
Have you tried the Note 10+ tip? I'd be interested to know if it works? See my other post for my reason...Sorry for the blurry pic. This is just a quick comparison before I give my feedback.
Thank you!!!This is what I ordered and after messing around with each of the tips, this is what I found.
- All the tips fit snug in the N20U S-Pen
- The length of the tips appear to be the same as the tips in previous models
- **ONLY 2 worked but are far from perfect and were hit or miss depending on the app**
- **All tips worked fine ONLY if the tips aren't pushed completely in** This is dumb because when using the S-Pen the tips will eventually be pushed all the way in.
I would recommend that people save their money on this one. Keep in mind however, I may have gotten a bad batch. I've ordered from another seller so I'll see how those work.
I've never needed to replace the tips. Do they physically wear down to the pen itself or do they wear to a point where writing just becomes rough?This is what I ordered and after messing around with each of the tips, this is what I found.
Ordered the Samsung Kvadrat case. Was on sale for $10 off when I went to the site on my phone for some reason.
I love my kvadrat case... but then someone had to say that cloth is not good in covid since it can’t be cleaned. So I stopped using it. Maybe I should get the UV sanitizers...
