SopiGuard Skins
Serkle K
1,529
86
48
I ordered 2 new skins earlier this week, and they came in the mail yesterday. Im going to remove my DBrand skin and replace it with SopiGuard.
I found them last year and used them on my Note10+, and I loved them! So much, I ordered about 5 total, and I only made it through 3 of them for the year. I like their offerings and they have a lot of the same textured ones that DBrand and SlickWraps have.
I am still waiting for my SlickWraps to come in, and I ordered them August 8th, the same day I ordered my DBrand skins, and I got those the week after I got my N20U.
SopiGuard is also cheaper and ships a whole lot faster. I am in no way paid or sponsored by SopiGuard, but after my use of them last year, I couldn't wait for them to get their skins, and I'm ready to swap mine out.
I got a Frosted Blue and an Emerald Green. I think I will go with Blue for a little bit, before I switch back to a green skin.
I also have a camera glass protector coming tomorrow from Caseology, and I'll put that on, and then the camera skin over top of it.
I like that Emerald... I bought from them once and they were quality and good look..
How do they compare to D brand skins?
Cheaper, same textured skins (camo, honeycomb, etc.), faster shipping. And also, my current DBrand skin is short, it is lines up at the top and around the camera hump perfectly, but there is a gap at the bottom of the phone and the skin doesn't reach the bottom of the device.
Probably going to add one even though I have a case on it.
So, I just wanted to update everyone on the Sopiguard skins I have. Yesterday, I finally got my Caseology camera protectors, and I put it on last night. It works great!
So with that finally being taken care of, today I went ahead and swapped out my DBrand skin for the Frost Blue Sopiguard skin.
These particular skins (Frosted colors) have a Matte finish and are thinner than the textured skins. I mentioned that because, I was able to salvage the DBrand Seafoam skin.
Lastly, the Sopiguard skin is a very nice, complete, fit and finish. The skin coverage is great, side to side, and top to bottom. I also included a picture with the device in my Caseology Skyfall case.
I already know in about a month or so, I'll likely be switching to the Emerald Green one, to coincide with the NFL season. #FlyEaglesFly
Also, here is a few quick pictures of the bottom of the DBrand skin I was using on my Note20 Ultra. You can see the gap pretty easily. Not a huge deal, but not the kind of quality I expected from a company like DBrand. The frosted skins I am using are thinner in comparison to the pastel skin I was using, but that is the only major material difference I have found with the two types of skins. I do know the textured skins that SopiGuard is using, are the same ones that DBrand and SlickWraps uses, so you get a better overall deal with SopiGuard, because they're less expensive without the "constant sale" that the other 2 companies have. And their shipping is a lot faster in my experiences between the 3 brands.
Although you are an Eagles fan I still like you ...phone came out great ...really digging the color and wrap..
#GoBigBlue
So, after 2 weeks of blue, I decided to swap out into the Emerald Green skin.
This is what a Green Note should look like! 😍😍😍
I just ordered these from SopiGuard. It is annoying that EVERYTHING you order for the Fold 2 requires a WAIT. Very frustrated.
Can you use this with a case ?
Yes, it's one of the reasons I use a skin and a clear case. Well, that, and the fact that Samsung doesn't offer their colors across all devices.
The last picture is the Blue skin I just took off.
It looks nice in the skyfall. Might get me a red or black skin.
Crissy Doug
