A
AC Question
Galaxy Note 3 SM-N9005 LTE problems
Hi, I have one SM-N9005, I recived the update to lollipop 5.0... I made the update... my note 3 are showing the option "LTE/WCDMA/GSM (auto connect)", I think don't need root my phone because I already have this option without root... BUT if I put a 4G chip on my note 3, It's never work, only get 3G speed... I use the same chip in other phone and the 4G works fine...
Somebody have the same problem?... have the option "LTE/WCDMA/GSM (auto connect)" but your phone never works with 4G?
