Where do you purchase SD cards and batteries for the note 4!? Also what's a good make and model for SD cards!? Any links!? Cheers!
Closingracer, my experience with SanDisk SD cards been just the opposite!
I have two ultra 64 gb class 10 and now a 128GB ultra class 10 and the all work perfectly.
The 128gb is in my Note 4 it is perfect. I make sure I format the SD card in the device I am using it in. Along with not shutting the device off during a write to the card. Also it has been my experience with SanDisk they will quickly stand behind their products with a quick replacement.
Again, that has been my experience.
I always have at least 1 spare battery with me at all times. You will never here me complain about pour battery time because the Note 4 has a REMOVEABLE BATTERY, that it seems few users take advantage of, judging from the many poor battery threads.
Thanks for the feedback guys! I think I'll hold off on the spare battery for now because It last me a day and half easily anyways, but will be good in the future to have. I'm definitely thinking of an SD card asap though. Tough choice between SanDisk and Samsung. The Sandisk has a better 64GB price than the samsung... Decisions decisions!
Shop around. I'd check with eBay and Amazon. You may be able to get a better deal on eBay, if you compare sellers' prices.
Eww micro sd cards from China ...l
There are sellers listed in this country. You just have to check the sellers' location, if you don't want to buy from overseas sellers. And don't disregard them simply out of hand. I've bought products from Korean and Chinese sellers, and have been very happy with them. (BTW, where do you think these cards are made, anyway?}
