ajhallx
i am talking my phone back too bt connects and runs fine but also disconnects over and over again i can't listen to 1 song straight with out this happening
There is nothing wrong with your phone if the only issue is Bluetooth connection.i am talking my phone back too bt connects and runs fine but also disconnects over and over again i can't listen to 1 song straight with out this happening
Check out the forums for your car manufacturer. You will find threads specific to this issue. You can then find out if there is a firmware update available.I am having the same issue with Verizon note 4, sometimes my bt will lose connection and I have to restart the phone to get it to work. I have the same issue with the bt in my 2013 nissan. I currently looking for a solution
I've found that music streaming apps will show correct data on first song but no song updates afterwards, but the song length timer works on all songs with Google Play Music.
I have the same issue with my Note Edge. After blaming my car manufacturer they investigated and found that Samsung is aware of the issue affecting the note 4 and the note edge. These phones are using a new BT version. Supposedly the version will be corrected or rolled back with the next software release - when ever that is.
LaTuFu, have you been able to get S-Voice working with your car? I have a 2012 Charger and just got a note 4 (Was on WP prior). I can connect with bluetooth but can't initiate a connection to the phone to use s-voice. The car has two buttons for voice but both connect to dodge's voice control system. My old $20 bluetooth adapter had a phone button that you can press and it connect to the phone. I got around this with WP by dialing a number that called the phone and started Cortana (a little know but very useful feature to me).
Anyway, how is voice activation and control working for you after the update?
Sadly, no. You could try forgetting the phone from your car's bluetooth settings and then forgetting the car from your Note 4's settings and try repairing again. It seems like each time I re-pair the situation improves slightly.
Can you let me know what software version is your radio?I have a 2014 Corolla LE ECO and my notifications are delayed when displaying on my dashboard display. It takes 5-10 seconds for it to display on the screen after I received a text on my phone. Also, sometimes display shows the wrong song and regardless how many times I change it, it stays on the one song.
Do you have these issues?
Unfortunately, I'm not going to be any help to you. I disable S-Voice on my Galaxy devices. I use OK Google and that's pretty much it.
When I connect to BT on my vehicle, the only voice commands I use are with the vehicle's system, not my phone.
