DarkUncle
What's the difference between Nova and the paid version a.k.a Nova Prime?
Without starting a new topic - is Nova launcher the best one out there?
I've noticed I can't use the lil swipe motion to reduce screen size on Nova. It just slides to another screen. I can use the side bar deal though.
If you want the best of both worlds, use the nova launcher, and put the Google Now widget on the far left home screen
like so:
How do you do this?
The prime opens up more features than the free version, that has to do with look and feel enhancements of the launcher. One of my favorites is the gestures on the home screens. for example I can swipe down from anywhere on the screen to bring down the notification panel, or pinch to zoom to open up the gallery, or swipe down with two fingers to say open wifi. All these can be customized to do different things.What's the difference between Nova and the paid version a.k.a Nova Prime?
Which part? if you are asking about the widget, you can go into the app drawer and select the widgets tab, and look for the "google now" one, and place it on the left most screen. and uncheck infinite scrolling of screensn (in the Nova settings)
hope this is what you asking about. If not, let me know what part of my screen shot you are asking about.
im guessing you have to uncheck the infinite scrolling? i dont see a google now widget..
I just checked this with Nova and air command pops up when s-pen is detached.When you remove the s pen on a non touchwiz launcher, do you get the air command?
I've never used a launcher before and usually just relied on ROOT with my classic Thunderbolt for customizations so pardon my stupidity here but, is it easy to go back to TouchWiz in the event that I dislike Nova?
Mainly just widgets like
Calendar
S health
Facebook unread badge
All the s pen features will work.
yeah I'm using nova now and nothing is missingThere's an option for a Facebook unread badge and other unread badges. You need to have the Tesla Unread for Nova plugin installed. Then go into Nova Settings > Unread Counts > TeslaUnread Settings and scroll toward the bottom and select Facebook under Labs. Works great on my Note 4.
I've been using Nova prime since I got my Note 3 and use it again on my 4. I have tried a few other launchers, but always go back to Nova prime. I don't have the widgets for Google now set up, but I've assigned a double tap on the home screen to open Google now.
