I notice that there aren't as many camera modes pre installed on the 4 as they were on the 3..or Am I missing something?
Click on download and you can download more modes from the Samsung store.
Did you put the note 4 in sports mode?
Really what is probably happening here is that the note isn't setting the ISO high for a shutter speed to stop motion, if you put it in sports mode it is telling the phone that you want as high of a shutter speed as possible.
Other option is to use a different camera app that let's you take control of shutter, f-stop and ISO so you can control the outcome youself
Have you tried burst mode?I've tried the Sports mode and it made absolutely no difference whatsoever. I LOVE my Note 4 camera but i've yet to get an action shot that was without blur.
Sent from my Verizon Samsung Galaxy Note 4
Yes it takes lots of images in successionI haven't yet. I've been hesitant to do that because I assume it takes shots in rapid succession? I have a pet peeve with deleting duplicates of things from my phone, and I was afraid i'd end up with crap loads of similar shots. However, if it means getting a crisp shot with no blur, i'll be all over that.
The iPhone's camera has always been light years better than any camera Samsung has had on their phones so iI never expected that to change. Overall, I still wouldn't trade anything to go back to the boredom of an iPhone.
Sports mode seemed to work just fine for me. This was zoomed in all the way. Unfortunately I was in the upper deck.
This shouldn't be much of a surprise...Samsung smartphone cameras were never good with low light
yes they do its just samsungs software processing needs work.
This wasn't really about low light and that's it.. It was about low light + movement. Or well I should say.. It under performs in movement. It's okay in still low light if you hold it steady.
But what smartphone camera out there does movement in lowlight well? You would a mirrorless or dslr for that.
I took some shots of the Note 4 and 6 Plus, in low light and motion. Top are 6 Plus, bottom are Note 4.
