Same here. I want to be able to have vibration on each key pressed but the box to enable it is already grayed out.I was looking to add the handwriting Pad when s-pen is detected under Samsung Keyboard settings but I see it's grayed out. Does anyone else know what to do?
I think i found a fix for this.
For some reason the "power saving mode" greys out this feature.
Disable power saving mode and it should not be greyed out anymore.
If this doesnt work
Goto
Settings
backup&reset
Reset settings
Reset settings (bottom)
This will reset phone without deleteing apps and pesonal data
Kind of a soft reset to factory default settings
Good luck
