Modern batteries should not have severe memory issues or overcharge problems. And if you are using the stock charger you should get a full charge in an hour or so.
I'd suggest one night make sure you have a full charge before going to sleep. Leave the phone alone overnight and see what you have in the morning. If it is way down after a night of non-use, then you have a problem. Something doing a lot of syncing, weak signal or problem with the phone.
Sent from my GT-N8013 using Tapatalk
well I tested it, I slept about 10 hours and the battery dropped from 100% to 93%.
7% in 10-9.5 hours, the phone was alone overnight. (I received several calls and messages even I did not answer)
what you say about it?
That is completely the opposite from my experience with the GN4.
A full charge easily lasts me 3/6 days* with heavy use (internet, calling, texting, chatting, email, apps, but no obsessive gaming, no long hours of video or streaming; when I want/need that I'm on USB). So I usually charge every second or third night when the battery is between 30 and 40%. I charge slowly using a USB cable connected to my laptop. I always leave it charging until the morning. I don't disconnect when it's at 100%. I prefer to sleep. The battery and charging software takes care of itself.
I used the exact same procedure with my previous Notes, but their batteries endured not half as long.
*10 days (or even longer) in power saving mode!
So TBH I can't relate to your battery woes at all.
You're telling me you are with battery from 3 to 6 days and the battery holds for you? Or I did not understand you.
if you mean the battery saving mode/power saving mode, then it makes sense.
about I will try to charge it with a usb cable on computer it's a great option. But wait, how long the battery should holds for normal use without power saving mode? 9 hrs? 8 hurs? 10 hrs? normal use of course.
thanks!
