Samsung Galaxy Note 4 using an hdmi adaptor
Kjthomas0724
758
I recently bought a hdmi adaptor from a website. Was told it would work with my Note 4..I can't seem to get it working. Are there any tricks to getting it to work???
Kjthomas0724
758
Re: using an hdmi adaptor
This is the adaptor I have. If this is the wrong kind can you tell me where to find an inexpensive one that will work
Rarry
154
A Chromecast and the Allcast app will do the same job most of the time. Also a lot of TV's have DLNA, though often called something else, but the phone will play video to it if it is enabled.
Kjthomas0724
758
Are there any specific setting in my phone I need to check for it to work??
sly11
24
Make sure to plug the usb or micro usb for power at same time cause it won't work if you only plug hdmi
ChemMan
677
Yea, many of them,the full sized USB has to be plugged into a powered USB for the thing to work. And with the Galaxy you need the 11 to 5 pin adapter mentioned earlier.
redkid
6
Who do you guys recommend for a good MHL 2.0 with RCP for Note 4? I found one on cablecables but not sure if it's any good. Thanks for the help
Kjthomas0724
758
I decided to buy a chromecast and I love it. Don't have to have my phone plugged in and it works great!
Kjthomas0724
758
I decided to go with a chromecast. I don't have to have my phone plugged up to cords and it works great!!!
Cho CoMo
3
The problem with Chromecast....Allcast...type solution is that you have to have an internet connection.
The way they actually work is to direct the Server they are receiving their stream from to sent the identical stream to whatever device you want to "cast" to.... It is not actually being sent from your device.
MHL does send directly from your device via the MHL to HDMI dongle.
If you are only able to get cellular connection (not internet), you'll need the MHL dongle to put/cast your display onto the Tv.
ecstasy89
