1. road_kill's Avatar
    So out of the box the Note 4/E both only have lte as the only data option for mobile data. Is there a way to change it so I can switch between edge, 3g, and lte at will like you kinda can do on the iphone, or does it have to be rooted or am i aol/sol? Thank you
    03-04-2015 08:33 AM
  2. dpham00's Avatar
    It should automatically switch between networks. If you mean manually switch, I believe that requires root on the att note 4.
    03-04-2015 09:04 AM
  3. road_kill's Avatar
    Yes to manually switching, my bad, and the att Note 4/E is not unlockable so im sol, man we need a bounty out for the note 4.
    03-04-2015 09:14 AM
  4. muzzy996's Avatar
    There already is a bounty over on XDA. It stands at around $5k , $10k if you combine with Verizon bounty .
    Sent from my SM-P900 using Tapatalk
    03-04-2015 09:23 AM
  1. ATT HTC Updates
    By Racn1320 in forum HTC One M8
    Last Post: 03-05-2015, 08:46 PM
  2. Can I transfer all network through Bluetooth?
    By T0mmiB0iEway in forum General Help and How To
    Last Post: 03-05-2015, 12:49 AM
  3. Replies: 1
    Last Post: 03-04-2015, 11:35 AM
  4. Replies: 1
    Last Post: 03-04-2015, 01:33 AM
