1. zorg's Avatar
    Hi,
    I use a lot the Galaxy Note at my desk, doing tethering or just using the phone sitting in the same place for hours, near a power point (socket).
    To avoid using the battery unnecessarily, couldn't I use the phone without battery, plugged to the socket?
    Thank you in advance.
    02-20-2016 11:08 AM
  2. nahoku's Avatar
    Don't know. Have you tried it?
    02-20-2016 07:24 PM
  3. Miller6386's Avatar
    02-20-2016 07:32 PM
  4. Jay Sacks's Avatar
    You don't need to remove the battery. Once the charge reaches 100%, the phone will run off the AC.
    Rukbat likes this.
    02-22-2016 01:44 AM
  5. ssundaybay's Avatar
    Impossible! Your phone won’t work as a laptop. When you remove the battery you break the charging circuit. When you take out the battery and turn the charger on, you lose the circuitry, cause the thing you call “a charger” isn’t a charger in reality. It simply provides your device with power right out of the socket. The real charger is your battery – it regulates the voltage and makes your device work. If the battery is not compatible with your phone you’ll kill your beloved device.
    _YoKolorMeBadd likes this.
    02-22-2016 02:46 AM
  6. zorg's Avatar
    Thank you for your answers.
    I'll do what Jay Sacks said. When I'll be at my desk for hours, I'll use the phone plugged to the socket and with the battery in it.
    Sometime ago people said that batteries could be damaged (because of the heat or something like that) when plugged, but I think that's no true any more.
    02-22-2016 06:42 AM
  7. natehoy's Avatar
    That will work fine. While leaving the battery at 100% voltage for extended periods of time is not the best thing in the world for the battery, the overall damage done is very minimal, and probably unnoticeable over a year or two.
    Plus, a new battery for the thing is $10-20. I currently have a total of 4 batteries for my Note 4. It's a whole lot easier to just pop a battery out and pop a fresh one in than walking around with a battery pack hanging off the delicate USB port.
    02-22-2016 07:55 AM
  8. Brew Swayne's Avatar
    This was more true several years ago when early smartphones weren't really smart enough to stop pumping juice into the battery once it was fully charged.
    I wouldn't use my phone for 8 hours straight with it still plugged in, but a 10 min here, 20 min there over an extended period of time shouldn't hurt it.
    02-24-2016 10:35 PM
  9. Jay Sacks's Avatar
    I think you are pretty safe leaving plugged in as much as you wish. I am going on 4 years plugged in with my Droid x as a clock.
    They are now advertising new apps to use your old smart phone as security cameras. Plugged in all the time of course.
    03-08-2016 06:52 PM
  10. Rukbat's Avatar
    Since I've been using my 2-1/2 year old phone exactly that way (plugged in for days) and the battery still has about the same discharge curve it had after its first conditioning, I think it's safe to say - without all the guessing - that it's safe to use a phone that way. (I still keep my older phones - pre-smartphone-era - plugged in too. I haven't run discharge tests on the batteries, but they seem to work about the same as when they were new.)
    04-05-2016 12:57 PM
  11. ahpathak28's Avatar
    Did you try this??
    10-05-2016 11:00 AM
  1. Replies: 7
    Last Post: 10-11-2016, 06:01 PM
  2. How to run after market games?
    By sarath pathur in forum Ask a Question
    Last Post: 02-20-2016, 12:19 PM
  3. S notes - wish to sort them
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 02-20-2016, 10:54 AM
  4. How to unlock my Galaxy A8 phone?
    Last Post: 02-20-2016, 10:50 AM
