clevin
with each update, you may want to try clear the cache of the system and reboot it a few times.
But doesn't factory reset take you back to the original firmware the phone came with?
Also, how do I "clear the system cache"? Will it result in loss of my data or will everything remain as is?
Had it for a few days now, thinking about taking it back. Had a few nights of 30 percent drain on stand by. I think I sorted that out, as I had 4 last night, but it's still just not good. Most of these power breakdowns I see are dominated by screen..that's at the bottom of my list.
2 pm on a very light use day and I'm at 55. By light use I mean maybe a half hour of screen time
Yes. It installed all the apps I had on my note 4. It's crazy that its this much better than the s6. Really didn't buy any of the efficiency and optimization stuff at all. But something is working.
Maybe something you deactivated with Package Disabler is having a negative impact?
I was at 6 hours SOT after 16 hours off charger yesterday before I hit 15% remaining.
Took the boy to see Santa so I tossed it on the charger just to be sure I had more than enough juice for any photo ops that may come.
From my Platinum Gold Note 5
Today was my first "normal" day with the Note 5. Normal for me means getting up around 8 am, spending a little time on my phone, then heading into work around 120 pm. The main difference in my day is that since I work in a state prison, my phone sets in my car for 8.5 to 9 hours while I'm inside work. Very happy to report that I walked into work with 93% battery and still had 87% when I walked out, meaning a drain of only 6% for the 8.5 hours my phone set unused in my car.
That's right in line with my Droid Turbo, which of course had a larger battery, so 6% drain on it was actually more mah lost than on the Note.
Can you share what's disabled on your phone if anything? Also any specific settings we should keep in mind.
What was your trick to cure stand by bug? That alone is a major accomplishment.View attachment 208069
Package disabler and greenify. After doing that, it's much better.
I also did a clearing of the cache last night and turned on advanced calling. The cell standby isn't at the top of my list today, but I'm not convinced the battery is any better.. right now at 1.5 hours sot and at 44%. That is letting it sit idle all night though
Wow that's really bad you should go and see to exchange your phone for another at 1.5 SOT i usually am at 75 to 78 %Package disabler and greenify. After doing that, it's much better.
So..went to Verizon today to try and exchange and they wouldn't do it. They insisted that my battery numbers were "above average" after they ran their diagnostic tests. Wtf.
They also said "you shouldn't believe everything you read on the internet" and that I the gsam battery app was damaging my battery. . Idiots.
I would call instead make some stuff up so they can sent you another.So..went to Verizon today to try and exchange and they wouldn't do it. They insisted that my battery numbers were "above average" after they ran their diagnostic tests. Wtf.
