Dhawk1202
I'm still using Launcher Pro. I'm just waiting for Federico to push that new build from scratch.
Hahahahahahaha! Good ol Federico. That man was ahead of his time.
It really was one of the best of its time. What was the other of that era? ADW? I dumped both of them for Go and then Go for Nova and Apex.Hahahahahahaha! Good ol Federico. That man was ahead of his time.
Nova Prime. Banded Icon set with 6 on bottom. Set home button to launch app drawer in Nova settings and hide status bar with swipe up gesture to show it. Wallpaper from an icon pack (can't remember which one.) Dashclock widget with some extensions.
Sent from my SM-N920V using Tapatalk
It's all stock extensions, apps with extensions, and dash notifier which uses the built in notifications settings. I've also added a battery extension. All seems to work fine.I thought that Dashclock wasn't compatible with Lollipop, but I'm happy to see I'm wrong. Is this a beta version of Dashclock? The comments on the most recent (I think) version on Google Play seems to indicate it only works through Android 4.4. What extensions do you use?
Dash notifier works with whatever app you select and I think you can do up to 9. I use hangouts for sms and that works. For phone calls I use the stock extension. I haven't noticed anything not working.Thanks for answering so quickly. That sounds great. Is the Dash notifier able to work with SMS and missed calls?
Nova launcher with Urban theme. 2nd page includes most used widgets.
I just learned how to edit icon names and moved a few things around...
Sent from my SAMSUNG-SM-N920A using Tapatalk
What icon pack? Looks good
