Verizon Galaxy Note 5 on T-Mobile Network
Sep 21, 2013
8
I'm switching to T-Mobile and they're telling me that my Verizon Note 5 will work on they're network. My question is does the Verizon Note 5 have band 12 to take advantage of T-Mobile's enhanced LTE and will wi if calling work? I have looked all over and can't seem to find a solid yes or no.
Sent from my iPhone using Tapatalk
LeoRex
Retired Moderator
Nov 21, 2012
6,223
You won't have Wi-Fi Calling... you need to have a T-Mobile model (loaded with T-Mobile's flavor of the Note 5 firmware) to get that. Not sure about VoLTE and Enhanced LTE stuff, that might also require T-Mobile specific software. And the Verizon model (SM-920V) has band 4 (which is T-Mobile's main band), but it won't have band 12.
CDMA: 800, 1900 MHz
FDD LTE: 700 (band 13), 1700/2100 (band 4), 1800 (band 3), 1900 (band 2), 2600 (band 7) MHz
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
Also mms might not work,and it doesn't support h+ 4g aws.
Sent from my Verizon Samsung Galaxy Note 5
KiwiCoalBattery
203
I've tried it with a T-Mobile post-paid SIM card. SMS and voice work fine, obviously. Data is slow, but that's just because the Verizon doesnt' have the right bands.
All four of my Verizon Note 5 phones have AT&T SIM cards in them and they all work perfectly with AT&T 4G.
Just did a Speedtest.net tes a few minutes ago and shows I'm getting 18mbps down and 3mbps up from the AT&T 4G network, which is quite respectable, considering that is' on a Verizon Note 5. Verizon's own 4G speeds are about the same for my area.(rural to suburban)
AmeliaRodriguez
