Best sd card for note 7?
Savoy
132
4
18
Ok so i haven't bought an sd card since my note 4. That has a 64 gig in it. I think it was a San disk i think class 10? So for my note 5 i couldn't use it which that phone is going to my wife. It's 64 gig and plenty of space for her.
Anyway i want to order a 128 gig sd card for the note 7 which i just pre-ordered but i want to make sure i get the fastest one i can get. I'll be taking the fit2 as the pre order bonus so I'll buy this. 128 will be fine for me.
Thanks.
SpookDroid
Ambassador
Jul 14, 2011
19,302
555
113
As long as it's at least a Class 10 (faster transfers are better, especially if you're thinking about doing 2K video) and from a reputable brand, you should be fine. The usual suspects are SanDisk, Samsung, etc.
HOWEVER, Samsung and Samsung always work better together, so their line of SD Cards are probably your best bet.
anon(782252)
4,097
Thanks guys. I didn't realize 128's were still so expensive. I'll Hunt around on amazon a bit.
The 128's are still pretty expensive if you want write speed in the 80+ range. The Samsung Evo line is pretty solid as well, much cheaper, but much slower write speed as well.
PlaybookFanatic
945
I was planning on getting the fit2 as the pre order bonus.
I didn't think anyone was actually getting that, especially since the 256 is the top of the line that Sammie has at the moment (and saves them 250 bucks). But if you'll actually use the watch, then go for it. I have a fitbit, Gear S2 and a LG G Watch R. You forget to wear them often lol.
Kilroy672
1,243
13
38
How good is the 256 gb card that Samsung is giving away? I'm sure its not top of the line but might be good enough for me.
dkbb
16
I bought a san disk 200gb card last month, just for the note 7. Should I use it or get the free samsung 256gb card?
Non
