1. noordzy77's Avatar
    Are you going to use it? What exactly does it do? Seems it brings over all your apps and accounts.
    I feel like when I get a new phone I want to settle into it first before I install tons of crazy apps that I don't use quite as often. Obviously the important ones I get set up, but I think I'd rather handle everything manually.
    08-18-2016 02:25 PM
  2. jlczl's Avatar
    Nope. I like to be meticulous about how I add things and make sure no garbage gets loaded up.
    nonie likes this.
    08-18-2016 02:30 PM
  3. EchuOkan1's Avatar
    No, I like a clean slate before I started adding thing.
    nonie likes this.
    08-18-2016 02:41 PM
  4. russel5150's Avatar
    I always set mine up myself. I move any music and pics to my laptop, and spend time downloading the apps i want.
    It takes longer, but i dont mind, that's the fun of getting a new phone. When i walk out of the store my contacts are there, other than that i do everything else myself
    08-18-2016 02:46 PM
  5. jc2859's Avatar
    I was anxious to get using it for everything, figure I can wipe and start again otherwise. Process was pretty smooth.
    08-18-2016 02:48 PM
  6. Hurleygm's Avatar
    +1 For clean slate. I like to install as little apps as possible and only download something when I need it.
    08-18-2016 02:51 PM
  7. skatergirl's Avatar
    I am going to smart switch a couple of apps but not everything
    08-18-2016 03:17 PM
  8. mpazevedo's Avatar
    I'll use it for photos and other miscellaneous downloaded files, everything else the google account (contacts, email, calendar, etc.) will take care of it.
    08-18-2016 03:20 PM
  1. Android auto not showing all contacts
    By Snakeoil999 in forum Android Auto
    Last Post: 08-21-2016, 09:35 AM
  2. Replies: 3
    Last Post: 08-20-2016, 04:58 PM
  3. Unable to resent password or Find ID
    Last Post: 08-18-2016, 06:50 PM
  4. Switch to Note 7??
    By Steve 601 in forum Samsung Galaxy Note 7
    Last Post: 08-18-2016, 03:24 PM
  5. 4G data connection not working honor 6 H60-L04
    Last Post: 08-18-2016, 02:05 PM
