Re: Battery Life has been phenomenal with the new Replacement Note 7 's
Nice! Are you using package disabler to disable anything? What are your settings?
Ditto...have no idea how you are getting that??
People who claim to get 3 days on one charge always will because they are obsessed with it. Those of us who heavily use our phones will always get 3 to 4 hours max. JMO
My setup isnt too dramatic or anything.
As soon as I received my replacement Note 7 I did a clean install, no smartswitch or cloud backup stuff.
I turn on the device and skip all the account setup to let it initialize everything it does on first boot.
Once that's done I go into settings and turn off all the motion gestures I don't use, which is most of them except double tap home for camera.
I change display to Basic and set the display to auto with the slider about a tick below the halfway point.
I then setup my Google account to sync mail, contacts and calendar but I change Google Play to not auto update apps since I wait to update my apps when I want to.
First app I install is the Samsung Package Disabler Pro and de bloat my device.
I turn off WiFi scanning, turn on developer options and change animations to .5, turn on BT and pair my headset, install Nova Launcher and use a dark wallpaper and then install the rest of my apps (about 30).
I also disable the built in app optimization because I've noticed when that activates it actually makes my battery life worse. I rather handle the battery optimization myself than let the system automate it.
Can't think of anything else special that I do. When I use my device heavily I will charge every day but can go almost 2 days typically on weekends. Either way I get 6+ hours SOT but if I'm traveling a lot through low signal areas (I'm usually in good T-Mobile signal area though) then my SOT will suffer. It can drop to as low as 4 hours. I think that's one of the biggest factors when it comes to battery life. This Note 7 however is definitely better than my previous Note 7 in the exact same conditions.
